Now that Ive done it...wouldnt do it again
Hi Ryan,
I had the same thoughts as you, so I decided to make my own.
Steps:
1: Make wood attachment block at attached to injector
2: Make wood copy of filter and attach to baffle
3: Join both with aluminium tubes at each corner, bending as required to make a shape that fits around everything and clears the cowl. (BTW hadnt fit my cowl yet....first mistake)
4: Fill inbetween the tubes with foam, spray foam etc and smooth.
5: Cover with plaster and sand.
6: Fit cowl (This should have been 1)
7: Attach sanded plug into position.
8: Try to put cowl on.
9: Swear.
10: Swear again.
11: Take off cowl,
12: Hack mecilessly at plug destroying previous nicely smoothed shape to fit cowl.
13: Replaster
14: Resand
15: Paint, and polish
16: Finally!! Wrap with glass. Cant bag it...too wierd a shape...so wrap with saran wrap.
17: Wait.
18: Peel off saran wrap.
19: Swear at voids because of no bagging
20: Sand, reglass voids, fill and sand.
20a: Wait some more
21: Refit.
22: Look at transition from duct to venturi. Rework interior with ramps to smooth transition.
23: Fill and sand again.
23a: Wait .......
24: Refit
25: Put cowl back on.
26: Check clearances again....VERY difficult to get sight line
27: Dont like clearances....remember engine shakes.
27a: Swear for quite a while this time.
28: Remove cowl
29: Slice forward part of duct off, reglass, refit.
30: Done.
There ya go.
Good thing I only make $0.23 an hour!!!
Chris
