GrayHawk
My older 6A is harder to pull & push than I think it should be. Also several others have noted that. When I pull it with the nose tug, I can hear some amount of brake noise on the main gear wheels. My question is, how much brake drag should be there. (I run 35# in nose tire, 32-34# in main tires)
For the main gear only (enough has been said about the bearing setup of the nose gears), I'm planning on checking the following:
- brake pad clearance
- brake pedal return springs
- toe in/out
- camber
- any misalignment of main gear
Along with the usual condition inspection items of bearing wear, repack, and bearing preload.
Any other thoughts?
- toe in/out
- camber
Any other thoughts?
