I'm fighting with my roll bar on my slider. I have it drilled and positioned properly, and in the instructions it says to add shims to the base of the roll bar to make it square with the longeron if required. I can't find anything on the search that helps me out. Has anyone else out there needed to add a shim to their roll bar to square it to their longeron? I need to add a tapered .063 shim to get it square. How will this effect the canopy frame fit? Is it too late to build a tipper? (just kidding, I want to look cool taxiing down the ramp
as always, thanks for the help.
Trevor
Trevor
