Roll bar bolt thru aft canopy deck question
mikehoover
How in blue blazes do you get the nut on the bolt of the aft 1/4 bolt thru the roll bar into the aft canopy deck? I keep thinking I need to scallop the bottom flange here but never a mention in the manual or plans that I have seen. Any suggestions?
Thanks!
<chuckle> no wonder I was confused :). But thanks for the empennage fairing experience, mine are now done without any pain (thanks to your heads up).
Thanks!
I made a nut holder out of sheet aluminum. With a little work you should be able to make a tool that holds the nut while you turn the bolt. No need to cut the flange back.
