I'm having a bit of trouble tightening the rod end bearings for the aileron push/pull tubes.
My question is, How did you tighten the jam nuts? Proper torque values for this part can be found on page 5-18 of the RV-14 manual and are posted below. If I hold the rod end bearing itself with a wrench, the tube rotates when I apply torque to the jam nut.
How did you keep the tube stationary? By the way, this is an AN6 bolt.
![2irr7zb.jpg](/proxy.php?image=http%3A%2F%2Fi64.tinypic.com%2F2irr7zb.jpg&hash=5029e6a38f96d9f926b7dbdfe2149684)
![2i20kdv.jpg](/proxy.php?image=http%3A%2F%2Fi64.tinypic.com%2F2i20kdv.jpg&hash=ee176c1349b022c4c972b196e79388ae)
