Hi Folks,
May I ask you which rod end bearings you are using for the Rear Throttle Lever for Vans RV8 from Aircraft Spruce?
See the link below for the throttle lever 05-04531:
http://www.aircraftspruce.com/catalog/appages/rv8quadrant.php?clickkey=8822
I found that the eyeball bearing - which would be used for the Vans rear throttle - is to wide and does not fit between the lever and the lever bracket from Spruce...
Pictures would be highly appreciated...![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you very much for your support!
Best wishes,
Anna
Best wishes,
Anna
