jazzbazzfazz
Member
I did the preliminary assembly of my rear spar yesterday and found that consistently the rivet sizes called for in the plans were 1 size too long (rivets being squeezed had a tendency to squoosh and topple a little sideways, etc.)
This was for attaching doubler plates to the middle and outboard portion of the spars, and "tripler-plates" to the inboard portions.
Using the next shorter length gave me beautiful rivet heads, though right at the limit of acceptable size. As you may remember, there are still numerous rivets to be set in assembly with ribs, brackets, etc. that will add to the strength of the join.
The questions are:
(1) Has anyone else encountered this?
(2) Am I better off with rivets just at the specs, or longer rivets that appear oversqueezed?
Thanks!
John Walter
RV-9A wings
The questions are:
Thanks!
John Walter
RV-9A wings
