CFI1513840
The F-782D Angle is attached to the F-7101 Gear Attach Web with LP4-3 blind rivets, but there is not enough room between the F-7101 and the outer skin for the rivet shank. The head sticks up about 3/16" and will not seat properly when the rivet is pulled. I was thinking about drilling relief holes through the outer skin, which will be covered by the wing root, to allow the rivets to seat properly before they're pulled.
I just wondered if anyone else had this problem and what you did about it.
