EJWash
Active Member
Sooo... After setting umpteen flush-head (AN426ADx-x) rivets in practice projects and on my RV-14 build, the manufacturer heads of my rivets are setting slightly proud of the surface. Not sure what I changed in my technique. Using a Boeing Urethane flat set, tungsten bucking bar, setting AN426AD3-4 rivets. Running 90psi to gun, pressure reduced with valve on gun.
Thanks in advance!
Thanks in advance!
