macrafic
Hey fellow builders, I'm looking for some tips regarding riveting the fiberglass parts on the RV (RV-7A, to be specific). I'm attaching the wingtips and putting in the wingtip lighting. Both require riveting and some areas can not be reached with the pneumatic squeezer.
Question, is it OK to use the pneumatic squeezer where it can reach. An example would be the nuplates that have to go along the entire top and bottom of the wingtip for me to use screws for attachement.
For those areas where the squeezer will not work (attaching the wingtip lens, for instance), can you buck the rivets? How do you do this to avoid damage?
I've been going along fat and happy and realized, when I reached this point, that I don't have a clue! I don't have scrap fiberglass to try technique; my saving grace is that if I damage it, I can always repair it (unlike aluminum). However, I'd like every chance of doing it right the 1st time!
Thanks!
Thanks!
