I am riveting the outboard bottom skin onto my first wing and it appears that either the skin has shrunk or the skeleton has grown spanwise by about 3/32 of an inch.
When I matchdrilled this skin on the jig, there was no gap at all between the leading edge skin and the main wing skin. Now, there is a definite gap...at this time, maybe a little over half a hole off at the main spar. It requires a little effort to get the clecos into the main spar.
I have only riveted about two bays along the rear spar and halfway up the inboard rib and a couple of rivets on the next outboard rib. If I continue riveting, should the skin start fitting better as the rivets hold the skin more firmly to the substructure? I have already riveting the aileron gap seal to the top skin. Is it possible that it is in effect pulling the bottom of the rear spar rearward?
Thanks for any advice or suggestions,
Wade
Wade
