The reason for the confusion, is that you mentioned getting "squeeze rivets". A rivet squeezer is designed to work on the exact same rivets that a rivet gun/bucking bar would be used to drive. In some tight spaces, using one or the other might be preferable and/or exclusive. Need more details. You didn't mean "pull rivets", did you?No I’m familiar with riveting I’m just unsure if the “almost an rv14” mod kit requires any special riveter like deep throat or swivel head etc. Or if there’s a particular unit to avoid.
I’m very comfortable riveting in many different ways. Career metal worker here. I just don’t know what specific needs this particular kit will entail that’s all. I’ll get it sorted out.I ordered this mod when I was building my RV7 and had it clecoed together before ultimately deciding not to install it. As has been said, I don't think you'll be able to get to all these with a squeezer. I think you might even need a 90 degree drill to drill out some of the old ones, but I might be wrong about that.
I'm all about encouraging people to learn new skills, but honestly, if you don't know how to use a rivet gun, real live parts on a flying airplane is probably not the place to learn. Either practice on scrap until proficient or get some help.
Even if you don't have a robust EAA chapter or likely airport bum to conscript, for the price of a rivet gun and bucking bars and whatnot it seems like you should be able to hire somebody to knock this out for you. While they are awkward to get to, It's only like 20 rivets or so.
Gotcha. Well then, when I was putting this together (with the factory crossbar) I seem to remember being able to squeeze some of them and having to use a rivet gun and bucking bar for a few that I couldn't get to with a squeezer. A 3X rivet gun and a tungsten bucking bar about the size of a zippo lighter will work for 99% of the rivets on an RVI’m very comfortable riveting in many different ways. Career metal worker here. I just don’t know what specific needs this particular kit will entail that’s all. I’ll get it sorted out.
