This afternoon,I was putting the finishing touches on the rib to rear spar attachment points and there was a AN426-4-8 rivet that wasn?t sitting quite flush in the countersink on the fork. So, I drilled out the suspect rivet and somewhere in the process, drilled out the hole a slight bit more than needed. When I re-squeezed the rivet the head didn?t sit flush in the countersink. I drilled it out , thinking that I could either use an Oops rivet in the hole or drill out the hole to the next size AN426-5-8.
Looking online, I didn?t see any 4-8 Oops rivets. I think that I?m faced with going to a 5-8 or accepting having the rivet head stand slightly proud in the countersunk hole.
Hopefully, someone will have a better solution to preclude stepping up to a 5-8 and still being able to set the rivet flush in the countersink. Thanks
Note-
The suspect rivet position is circled in green.
Note-
![op2.png](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fscale%2F50%2Fop2.png&hash=d44661e9213a3f547ce8190e4ff07b7d)
