There is a rivet on the F-01457 gusset that is kicking my backside. It is the rear most 426 rivet that is located in the "match drill" hole. I can't find a bucking bar that I can get into the area. It is inside the longeron, which is 1 1/4" high. There is also about 5/8" of space between the sidewall and a bracket. The bracket is thick enough so that I can't compress the rivet because the bucking bar stops on the bracket.
I'll try for pictures of the area, but it looks like I need an L bar. Brown tool has one, but it is .1 too high. https://www.browntool.com/Listview/tabid/344/ProductID/3059/Default.aspx
