Rivet gun
Terrybrd
Member
On the pulled rivets for the RV-12, is the nose of the rivet gun flat or concave?
I bought tools from a friend that built a Zenith 601 and his was concave so I just want to be sure that I use the correct one.
So far I haven't seen anything that tells me in the instructions, but I'm still unpacking the 1st kit and doing inventory.
Terry
I'm sure you'll get more advice from a 12 builder soon, but I believe the zenith is built with Avex rivets which use a special rivet puller with a concave nose that forms the rivet head. I don't believe the 12 uses these so a basic handheld or pneumatic rivet puller is what you will want.
Chris
Thanks for the info.
I have another puller with the flat face so I'm all set.
Started some parts today and soon ready to start pulling!!
Terry
Zenith provides flush rivets with their kit and has you modify the puller to form the rivet into a "domed" head rivet.
If the head is modified correctly, it should fit a standard dome head rivet. Try a couple on scrap. It will likely work fine.
When I built a CH-601HDS, I flush riveted the entire airplane. So I never modified the puller head.
