Bret S
Member
I'm a first time builder putting together the RV-7 Emp. and was wondering about the accuracy of Van's rivet length callouts. So far the first two rivet jobs HS-411 hinge assembly and the HS-609PP bars to HS-603PP rear spar are just "plane" wrong. I've only got too coats of SW-988 primer to add to the material thickness, so I don't think this can explain this problem.
I took the EAA SportAir Workshop and was taught to use the rivet guage. The next size longer than Van's callout for the HS-411 assembly is exactly correct. The next size longer for the HS rear spar is just barely too long, but the rivet called out is way too short. So, the class taught me to use the longer rivet.
Are other here finding this issue?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
