Guys....I am attaching the right elevator to the stabilizer and before drilling the hole to match the control horn to the center bearing I just want some feedback. The elevator swings easily and everything looks great. The only concern I have is from the instructions that state, "double check all dimensions." I checked the gap between the counterweight skin on the elevator to the end of the horizontal stabilizer. The distance is consistent along the gap. I checked the distance between the cut-out on the elevator skin where the rod bearings connect to the hinge brackets and they are the same....It seems like a perfect fit, but because I am an amateur I question when everything seems perfect. What other dimensions should I be concerned with before drilling the hole in the control horn?
