Pat Stewart
I have my Ailerons and flaps temporarily in place while I fit the wing tip and aft rib. I have set the torque tube to neutral per the drawing however that does not rig the aileron. Before I permanently locate the aft rib in the wing tip I want to make sure that the aileron trailing edge aligns with the wing tip when the aileron is neutral. I have not found anything in the plans to rig with. On the two RV8's I have built there was a contour template made from a full size drawing.
What am I missing??
Pat Stewart
What am I missing??
Pat Stewart
