After a few months hiatus from the project, I got back at it today. I riveted the front spar/rib together in the vertical stabilizer, but even with the best pressure and clamping i could do, the ends of the ribs came up a little bit. I'm not really happy with this result:
It looks a little worse than it is in this picture. The space is about half what you see, its just reflecting the height of the gap (top half is mirrored).
Should I drill out and try something else?
