rg400
bird
Its time to run a coax for my transponder and com. From what I have gathered, rg400 is good for this. I need a source for about 25ft and some connectors also. I also don't think I have a crimper for it. Any help would be welcomed. thanks in advance.
bird
I have had good luck buying this stuff from Stein.
He also has the crimper and ends for the cable.
Give him a call, you will be happy you did.
Aircraft Spruce also carries RG-400 and connectors. More importantly, while you are getting the crimper, be sure to get a wire stripper that is or can be set for RG-400. While you can use a regular coax crimper with the connectors, the stripping pattern is different.
