Sorting some wiring on an avionics stack that I suspect came out of another aircraft and was never really properly wired in the first place..... It consists of a KMA24 audio panel , two KX155 radios and a KLN89 GPS unit. Com 2 has the GS option and is connected to a KI204 ILS indicator. The indicator has a converter to resolve a composite VOR/LOC signal.
Its probably a generic answer, but I don't understand how the Comm and Nav audio and microphone connections should go together and the diagrams aren't helping me.
On the radio I have Audio HI and Audio LO. I presume that audio HI goes to audio input on the audio panel, but what about audio LO - does that go to earth? Same earth or different earth to the shields? Is there a reason why the Nav and Com audios cannot be wired using one piece of 4 conductor shielded cable rather than two bits of two conductor cable?
The mic and mic key connection between radio and audio panel seems clear enough but where (and this is probably really dim of me) is the connection to the microphone jack?
I'm guessing that the headphone output goes to the headphone jack, and there is a return to the (specific) speaker earth on the audio panel?
Be really grateful for some help on this.....
Many thanks
Chris
Many thanks
Chris
