I have fitted my prop control to my Woodward governor as per the Vans Firewall forward plans. Unfortunately the controller works in the reverse sense. Is it possible to clock my woodward governor bell crank, spring and rear housing thru 120 degrees by undoing the screws at the rear of the housing and repositioning the rear assembly so that the actuating arm will operate in the reverse sense thus allowing proper operation ie full forward to fine back to coarse. If I undo the rear housing will I be presented with all the internal items of the governor at speed and in a random manner! as I often find reassembly after such events impossible. I really dont want to buy a new governor because this one works in the reverse sense in this particular installation.
