Need to trial fit wings, then remove for painting. Think I should use close tolerance bolts to get an accurate position for drilling the rear attach bolt. Any problem removing and them reusing the bolts for final assembly?
Also will leaving out the one large bolt that hides behind the main gear weldment (RV7 A) cause misalignment when I drill the rear attach bolt.
Peter
Peter
