We have flown off our 25 hr and had hoped to have our restrictions removed today. Instead we got a call from a Superintendant at Transport Canada that our C of G is too far aft. And he will not remove the restrictions as is. He has also passed it by his supervisor in Ottawa.
Here our details, I realise we are very heavy, but we expected to pay the penalty in capacity, not grounding the plane.
Right wheel 683 lbs.
Left wheel 699 lbs.
nose wheel 336 lbs.
our empty C of G is 109.52" to the datum. (99.44)
Changes to our RV to me don't add up to the center of gravity change we are experiencing.
We have an electric Ray Allen rudder trim. Two 680 batteries where the Concorde battery was to be placed. Van's said one Concord would be heavier than two 680s. Dynon auto pilot servo mounted as per Dynon.And the two ADHRS are mounted above the battery location. Our paint is probably heavy and all parts were primed (interior as well).
We have a Flightline interior (leather seats).Sound Down insulation arround cabin area. Aerosport overhead console, arm rest, and quadrant console. Lastly a fair amount of Polyfiber fil was used to make a smooth transition from glass canopy to alum tail.
One of my build partners says this is what is giving us an aft C of G. He must be right but I'm having trouble believing that we are the only ones with an aft C of G as that is what Van's said today. They believe we have an error in weighing or in our calculations.
My question is that this superintendent e-mailed us stating that our RV must be able to load up 150 lbs in the baggage compartment , two standard males (193 lbs in Canada) a pilot and perhaps a co-pilot if our gross weight limit allows and not exceed our C of G. He adds in all the aircraft he has dealt with,they add ballast if needed to guarantee you can not go over the aft center of gravity. We think this is hog wash as a Cessna 172 for one can be over the rear C of G . If all AC had this feature why would we have to do a weight and balance?
My specific question is for the flying RV-10 . Can you load your RV-10 (without going over gross and over max baggage 150 lbs) and exceed the aft C of G limits? I'm not talking about flying it that way, just asking if it's possible to do? I think I know the answer.
Thanks Ron
Left wheel 699 lbs.
nose wheel 336 lbs.
Thanks Ron
