I battled that one too.
As John mentioned, CHT/EGT was fine. I did trim so the loop was uniform.
As others have noted, yes, this was fine and I did the same to trim them up a bit. The EGT/CHT harness is on a DB25, and the wires are 6' long, so plenty to go around.
But I ditched the spade connectors after the umpteenth wonky signal from an EGT or CHT sensor, and went with Omega mini-connectors. Rock solid ever since.
The 37-Pin EGT cable was another story.
I think you mean the 37-pin *Engine Sensor Main Wire Harness*, not the EGT/CHT harness. This one is also 6' long, which was plenty long enough for everything that I can recall (it's been over 10 years, so memory fades). If there *were* any that required a wire more than 6', I probably just bought some of the correct color code from Stein or somewhere else. No butt splices or terminals, other than one to distribute both 5V and 12V to things like capacitive converters and the like.
I tried Faston but the bundle was the size of a baseball and I felt it woule fail.
I tried a terminal strip but it weighed almost a pound. Nope.
The final solution was a 37-Pin D-Sub. I terminated all 37 pins on a Female and secured it FWF. The sensors all terminate on the Male. If I need to add a sensor, just add it to the Male. Much cleaner.
I did add one or two things, like an Aithre remote CO detector, and just added wires directly to the DB37 that plugs into the EMS. A bit of a pain to do it under the panel, but how many times do you have to add sensors after you're flying?
BTW, how do you just add a sensor wire to one half of the connection? You'd still have to run a wire from the female back to the EMS, unless you wired *every* pin on both ends when you installed it?
