Request for pics of tidied-up wiring for installed PH Aviation Flap motor
N14KR
Active Member
Hi All,
Does anyone have some pictures specific to the PH Aviation flap motor installed with the focus on the final wiring after connecting to the WH-00125 wiring harness? I have successfully installed the PH flap motor and have no issue with the wiring itself. I’m just curious on how someone tidied up the wiring after making all the connections.
The PH flap motor has a long cord that I’ll certainly have to shorten before connecting to the wiring harness.
Thank you
-Rich K.
not sure what you're looking for exactly, but it's a fairly straightforward install..
just 2 wires plus the position sensor.
I'm not using the WH-00125 harness. I used a few clic bond mounts to secure the wire and used a Molex plug for the connection. Probably could shorten the wires a bit.
