I want to reconfirm the tension on my legacy RV-12 stabilator cables and may therefore need to adjust/rotate the turnbuckle barrels. I built this plane 11 years ago and am comfortable with the control rigging process per KAI Page 32-14. HOWEVER, I may need to remove two and possibly four of the previously-installed MS 21256-1 Lock Clips in order to adjust/rotate the MS 21251-B5S Barrels.
My question is: How do I completely remove the Lock Clips? The Clip can be cut off and substantially removed but It would appear that the little hook end would then remain inside of the Barrel body. Is it OK to leave this Clip remnant inside the barrel or must it be removed by unscrewing the assembly or am I vastly over-thinking this issue -- inquiring minds want to know!?
ps --I have spare new Clips so that is not a problem.
