Replacement oil for Exxon Elite 20W50
I have an RV-7A with a Mattituck TMX IO-360 Engine. It has been using Exxon Elite 20W50 oil for the last 12 years. I am on my last oil change and the next one will have to be with another type of oil due to the discontinuation of Exxon Elite oil.
What is the consensus for a replacement oil? Thanks.
Yellow RV-7
I have the same engine with 900 hrs and switched to Phillips XC 20w50 with added Camguard.
The oil analysis comes back good. It's cheaper too and I haven't heard any bad reports.
Continental are recommending it for their Titan experimental engines for break-in and throughout life afterwards.
IF you want to stay with a semi-synthetic, AeroShell 15W-50.
If you do not care, then get Phillips 66 Victory 20W-50.
Both are good and meet the Lycoming requirement for the Series 76 engine additive package without adding any additional additive.
For winter time when it is possible that I may not fly for more than a few weeks, I also like to add Camguard to my engine with either of the two above oils.
Another vote for the Phillips Victory oil. I have used Phillips oils in all my aircraft for many years with great results.
