flickroll
My -8 has close to 350 hours on it. It will be going to Glo Custom the beginning of Dec for paint
, so I am busy taking care of details that need to be fixed prior to the journey to Glo. On the rear canopy, the filler over rivet heads of a number of the rivets that connect the skirt, canopy and canopy frame together is cracking at the exterior of the fiberglass, creating a small 'circle' around where the rivet is embedded. I did not build the airplane, but suspect the rivet heads are covered with epoxy/micro. I have thought of a few options to repair:
1. Using a small Dremel bit, grind out the filler material over the rivet head. Use flox or epoxy/cabo to refill.
2. Grind out the filler, drill out the rivet, replace the rivet with a new pop rivet, and refill with flox or epoxy/cabo.
3. Grind out the filler, drill out the rivet, tap the frame for 6-32, and install screws with locktite on the threads. Then refill with flox or epoxy/cabo.
4. And yet another idea is instead of flox or epoxy/cabo in the above examples use 3M Structural Adhesive which is every bit as strong as flox but remains somewhat flexible. It ain't cheap....around 40 bucks for around 10 oz. This stuff was used extensively during the construction of the canopy of my Christen Eagle II, and I never had working rivets like this.
I am inclined to do #1 above (although maybe with 3M), thinking a stronger filler than epoxy/micro will not crack later. I know this is not the first airplane that this has happened to. Opinions on the best (most permanent) repair welcome!
