ChiefPilot
It appears there is a chance I won't be able to fly out of the airport where I am working on my -6A (see http://www.vansairforce.com/community/showthread.php?t=50086 for details) and unfortunately I already have the wings installed - including the splice plates and close tolerance bolts.
The bolts were a pain to get in, I suspect they will be a pain to remove as well based on that along with the stories found searching the archives here. I'm more concerned about the potential damage from doing so - I am sure I'll need to hammer/drive/etc. the bolts out somehow as they were an interference fit going in. I'm concerned that there will be spalling inside the holes of the aluminum spar when the bolts come back out - is this a reasonable concern?
Thanks!
Thanks!
