Hi everyone
I?m at the stage where I need to mount the tail wheel mounting bracket between the F-711 and F-712 bulkhead. Every picture I see online has people mounting this bracket without the tail wheel spring installed. I?m concerned that if I remove it, it will be a real pain to get back into location with the hole orientated correctly.
If I remove it temporarily, does the spring need to be back in place before I river the mount in or can it be inserted once the mount and bulkheads are riveted together? Also? Any tips on the best way to remove and reinstall the spring?
Cheers.
Rob
Cheers.
Rob
