FlyingDiver
I removed the fuel sender mounting plate (T-1209) to install the SL-0070 inspection kit (and also reseal one weeping rivet). What's the recommended method for cleaning off the old proseal?
Is just sanding the surfaces down good enough? (I doubt it). Sand and then MEK?
