Chris RV6-A
Member
Have 2002 RV6-A that I purchased a year ago. During its condition inspection I noticed a leak on the inside of the right fuel tank. It would be easier to clean up and fix properly by removing the right wing tank. I drained the tank, I have removed all the screws holding tank to the wing. Are there any bolts holding the tank to the wing structure that I have to reach through the inspection access panel under the wing, or just need to remove all the screws, the nut and bolt holding wing to body, two fuel lines and electrical ground?
Chris
N613LE
Chris
N613LE
