SuperCubDriver
I intend to make the floorboards removable with screws and nutplates like others did. To get the rear floorboards F-830-1 and F-831-1 easier out of the plane they should be separated.
Here are two pictures on which my intended cut line is marked with a white line. The plan is to rivet an aluminum stripe under the rear floorboard parts with nutplates on their extensions where the front parts will be screwed on.
I also intend to cut out the rear floorboards around the F-445 Flap Bearing Blocks to get them out without removing the flap drive.
Question: Is it the right location to separate the floorboards? What else has to be considered I might not be aware of?
![](/proxy.php?image=http%3A%2F%2Fi124.photobucket.com%2Falbums%2Fp12%2FHerman61%2FIMG_4547_zpsl8sl4cxt.jpg&hash=9eafc15ca53471025b1c51d8c903e632)
![](/proxy.php?image=http%3A%2F%2Fi124.photobucket.com%2Falbums%2Fp12%2FHerman61%2FIMG_4548_zpsmkotrugw.jpg&hash=b295487ff15c463ce06b52a343bd7737)
