I'm in the process of fitting/drilling my floor skins onto my freshly-out-of-the-jig -8A fuselage. I am considering making the floor panels all removable by using screws & platenuts instead of pop rivets like many builders have done. Anyone regret doing this or not doing this? If you have done it, are there any tips that I will need to know?
As I see it, the biggest advantage to this is that components can be mounted (and accessed) under the floor later in the building process such as power supplies and autopilot servos. BTW, I am planning to install a Digitrack II eventually.
