Any pictures of remote mounted avionics? Avialiable?
Jaypratt Well Known Member Mentor Aug 22, 2017 #1 Any pictures of remote mounted avionics? Avialiable?
TS Flightlines Well Known Member Advertiser Aug 22, 2017 #3 Jay---I know this plane well---was involved in its build. NOPE--not mine Tom
akarmy Well Known Member Aug 22, 2017 #4 I put a shelf behind the baggage wall on my RV-8. Transponder, ELT, and ADSB box are mounted there. Rv8 wiring by Andy Karmy, on Flickr
KeithB Well Known Member Aug 22, 2017 #5 Jay: http://www.vansairforce.com/community/showthread.php?t=139728&highlight=Remote+avionics&page=2 Posts #12 thru 20
Jaypratt Well Known Member Mentor Aug 25, 2017 #6 GMU 22 ? Where are you mounting your Garmin GR 22 ? Thanks for the pictures!
N Nova RV Well Known Member Aug 25, 2017 #7 GMU 22 Vans has the adapter brackets now to mount the GMU 22 in the left wing AHARS mount. The wire harness already has the wires going to that location.
KeithB Well Known Member Aug 26, 2017 #8 Ditto on Chris M's response. I completed mine before Van's offered their bracket and used the generic Garmin bracket. All the wiring worked fine though I had interference issues with pitot heat power wires (separate threads).
