Remote pressure sensor mounting
Pittsartist
I'm fitting a Dynon EMS 120 at the moment with kavilco transducers.
Several "blogs" show people using a remote mounting on the firewall for pressure transducers.
Can anyone tell me where to get one ?. Can't see them on the Dynon site or 'spruce :confused:
When you hook up the hose from the engine to the sender manifold, it is common practice to use a fitting in the engine that has a small---like 0.050 " hole in it, called a "restrictor fitting".
That way if the hose fails, the rate of oil loss is vastly reduced.
Same kind of fitting is used for manifold pressure sensor.
