I am planning to use the Vertical Power Primary Power System (PPS) in my RV-14. I am beginning the firewall section of the fuselage kit and wondering if there are any adjustments I should be making to the relay doubler installation in order to accommodate that system. Looking forward to page 43-01 of the firewall forward kit plans, the master relay and starter solenoid are both intended to be mounted on the relay doubler, using two bolts each into the provided nutplates.
I could fashion a replacement for the FF-01402 Relay Doubler using the PPS template as a pattern. But anyone who has got that far into the plane would know better than I if there is room for the PPS in that position and if there are better places to mount it.
Thanks in advance to anyone who has gone before.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
