Reflex
The flaps, ailerons and wing tips are all set in a neutral position that is 3 degrees reflex as compared to the wing. If you use the vans flap positioning system, it has 4 positions......Up (3 degrees reflex), 0, 1/2 and full flaps. Normally take off at the 0 degrees, cruise at the up (reflex) position.
