hi all,
i am about to install my lexan rear window in my 12. it has already been drilled with a #27 drill as recommended in the manual. i have heard that better longevity may be had if the holes are bigger than #27. i can do the work in my shop and set the temp as high as needed .am i at more risk by having a drill bit catch and crack the lexan while i am drilling? what do you builders that have done this before recommend? should i leave all my #27 holes as they are?all comments are appreciated.
