JackinMichigan
We're in the process of spec'ing out the panel hardware and a question came up: Apparently the new Bose (and others) style noise cancelling headsets use a special 6-pin Redel connector as opposed to the old-style dual headphone jacks. That way you can power the headset right off the airplane as opposed to needing a battery pack. We want this in our plane, but we also want to be able to use our old standard headsets if we want to.
I've found adaptors galore that will adapt a Bose headset to an older 2-jack airplane, but nothing that will adapt an older headset to a Redel connector. Can someone recommend something?
