Now I need a word from the experts, I have watched a couple of utube videos on changing the main gear tires on an RV 6A, you might have guessed there are two ways to position the
red dot and the valve stem, one says align the red dot with the valve stem, the other says to put the red dot 180 degrees from the valve stem, the logic here being the red dot is the heavy point on the tire, put the extra weight of the valve stem 180 degrees from the heavy spot on the tire, and presto the tire is balanced, however it seems most mechanics disagree with this procedure as does Vans construction manual.
Jim Skinner
Exempt but dues in this case are a good investment
RV6A
RV6 regrettably sold
![Red circle :red_circle: đź”´](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f534.png)
Jim Skinner
RV6A
