Does anyone have any experience with these probes? Seems like they Princeton Electronics became RED and are now producing the probes. Their documentation leaves a bit to be desired but the way I am reading them the probe does not use plates like the older VANS probes did that people were putting in their aircraft. Looking to install on a 10, so likely a 24 inch probe with a 5 inch bendable section that would have a bend towards the top then through a hole towards the bottom of the tank. Since the copper contact is inside of the probe does it need to be secured to the bottom of the tank via proseal (not covering the opening) or is there another method to secure it within the tank?
Any input would be appreciated
