I have been ground running my all-but completed -12, and cannot get a positive amps reading on the dynon, and the voltage hovers around 12.
I went thru the paperwork and searched this forum and came up with DONT POWER-UP YOUR SYSTEM issue from September 09. Vans fix for this was Service Letter Sept 11, 2009. When building the FWF section I checked the revised plan sheet date and revision (45.05 rev 1 dated 09/08/09) and concluded at the time that this sheet revision must have included changes to overcome the regulator burnout problem. The coincidence of the Service Letter and the revised plan was plain. Now I'm not so sure. The revised plan still shows the Yellow wire going to the C terminal on the plug that goes into the regulator.
Eighteen months down the track its hard to believe Vans have no provided an ammended plan sheet to save new builders falling into this trap. How many regulators do they replace each month?
And its a clear safety issue too. As reported in the posts on this subject, the yellow wire is hot and has no fuse.
Tomorrow I plan to take my regulator to the local Ducati shop for testing. It failed my testing per Step 7 of the service letter, but I'm not that confident of my testing. Hopefully it's something simple I wired up wrong.
Rod
Rod
