Rear window sealant
MS19087
For those builders who plan to use screws to install their rear canopy here’s what I did. The plans call for pro seal. I did not want to use that in the event I ever needed to remove the window. I’ve seen examples of folks who had to remove the window and they really buggered up the surrounding aluminum. I chose to use this Bostik polyurethane adhesive. I know A&Ps who use this on certified planes. Easy to work with and easy to remove if needed and does the job. YMMV
