TCONROY
We are using the SikaFlex method of attaching our canopy and have had excellent results so far with the tip-up portion. We are now in process of fitting the rear window and I was able to rough it in under the F-774 top skin for the first time last night. Van's initially calls for a 1.25" flange width on the plexi (the width of plexi hiding under the top-skin). However, I don't see in the plans where a final dimension is called-out. It appears more plexi is removed when using the screws/rivets method since an aluminum backing strip is fabricated. What are others trimming the plexi down to? It seem the only issue would be ensuring the edge of the plexi isn't resting up against anything solid to prevent stresses in the future. The only area this could occur is the upper aft portion that would rest against the F-706 bulkhead. Suggestions?
