Looks like material was changed to plexiglass/acrylic Part F-1277-B in my updated working plan set.
Anybody know why the material change?
My uninstalled 2013 flat sheet of Bayer Makrolon Abrasion Resistant polycarbonate Part F-1277-A is a tad under 67-inches wide and 21-5/16-inches deep and 0.135-inches thick including protective covering both faces. It is pre-cut with facets to form approximate curves and has many, many pilot holes at the edges.
I plan to install it close to the end to maintain easier access.
Before installing my Lexan rear window, I polished the edge in the vicinity of the fuel filler. I also used proseal as a sealer in the same area. Fuel has come in contact with the window on 3-4 occasions, no cracks or crazing yet. It will eventually fail and will be a pain remove with the proseal, but I'm at 8 years now.....fingers crossed.
