RVG8tor
I am hoping someone else can confirm something for me. I am installing Van's rear throttle kit and I am using the Deluxe Throttle Quadrant up front. The rear throttle kit comes with some templates to show where the holes in the bulkhead need to go for the rod that will connect the front and rear throttle levers. I pulled a string between the levers aligned where the rod will attach, I then marked the bulkhead with this line. When I run the line down over the template (blue line in photo) the hole that will go into the 804 bulkhead seems a fair bit off. The DWG does say approximate location for the hole. The template for the hole in the 805 bulkhead seems to be spot on. I just want to know if others had the same occurrence as I am having. The other thing I would like to know is how close is the template with the inboard and outboard location of the hole. Any help would be appreciated.
![](/proxy.php?image=http%3A%2F%2Fimg214.imageshack.us%2Fimg214%2F8657%2Fimg3457id6.th.jpg&hash=afd69188c2ba517e07b4513f1a85bdd8)
Cheers
Cheers
