Hi all, I have tried a search but couldn't find the answer. I am building the fuselage without the wing kit, so I ordered the rear spar and stub spar pieces from the wing kit to properly fit the receptacles on the fuselage. Can somebody tell me from looking at my photo if I have the correct relationship between the W-1207B rear spare plate and F-1206C receptacle? Is my angle of mating the two pieces correct for the way the wing spar will actually slide into the slot in the fuselage? By the way, Van's sent me PN W-1207B-25, which I think is .025 oversized? I am assuming that is the right part, even though this is my initial attempt at shaping these pieces. Thanks for any info!
