Rear Seatbelt Bracket F857B
bmurrish
According to the plans it tells you to make the F857B bracket from AA6-125x1x1 1/2. I looked everywhere including the inventory sheets but I don't see it. Are you supposed to make it from the AA6-125x1 1/2x2x30 piece instead or is that for something else?
angle
I thought I lost the angle or used it for something non-rv related. I have the same issue, or at least it seems like it. was going to order the correct sized angle from spruce, but now since you have come across a similar situation, I'm wondering if the dwgs call out an incorrect size? if memory serves, there is also a piece of 1x1.25 angle?
I cut down the 125X1 1/2 X 2 to the correct size. The pieces aren't that long, so making the 2" section 1" was not a problem on a bandsaw.
I just questioned Vans about this a couple of weeks ago. Their answer was that the callout was wrong and to make it from the piece of AA6 125X1 1/2X2X30.
